Low-Output Low Pressure Control Valve for use with 9" x 18" Magma Gas Grills
main picture
We compared price of Low-Output Low Pressure Control Valve for use with 9" x 18" Magma Gas Grills across hundreds of online stores. We found Low-Output Low Pressure Control Valve for use with 9" x 18" Magma Gas Grills in 1 store with lowest price $43.99 in Camping World. For detailed price comparison of Low-Output Low Pressure Control Valve for use with 9" x 18" Magma Gas Grills check table below.
Merchant Price -
Camping World [show price]
Low-Output Low Pressure Control Valve for use with 9" x 18" Magma Gas Grills description from Camping World
These low pressure control valves are designed to convert all MAGMA Gas Grills from a Type-1 Control Valve/Regulator and 1-lb Propane fuel canisters to a pre-regulated, low pressure, LPG (Propane) systems. These stainless steel and brass control valves are designed to connect to the low pressure side of the regulator. Hose and tank fittings not included.
Customer review
Not good enough. :( I thought that Low-Output Low Pressure Control Valve for use with 9" x 18" Magma Gas Grills by MAGMA PRODUCTS is one of the best on the market, but I am very disappointed.
